S7 vs PCS7
cornbread
Feb 2007
madison, indiana
407
I'm getting confused..happens more and more often these days..
Looking for the differences between S7 vs PCS7. Do they both use the same programming software? Does the PCS7 just have more HP? I'm new to the Siemens world and I hope this is not a dumb question. Any help would be greatly appreciated.
I have a small safety application and it looks like the S7-300 would work just fine, but I also have another engineer telling me I should use the PCS7 platform.
I would just stay with Step7 and use distributed
safety
You said small, how much i/o are you talking?
PCS7 is for a decent size process.
Thats no problem for S7. If you need fast processing you should go with S7-400 but if its less dependant on processing speed you should go with S7-300
Actually, the fastest S7 CPU at the moment is the 319.
The advantage with S7-400 is the ability to make bigger programs, faster comms to CPs in the rack, redundancy with fast switchover, and RIUP.
To me it sounds as if a 315F-2PN/DP suits your application.
(but you havent described it very much though).
Here is a basic description of how PCS7 works. As mentioned, it is most likely overkill for your application.
PCS7 is more of a DCS system where you have a block in the PLC that has pre-canned faceplates for display in the HMI. You can also make custom blocks if you have a function that is not covered by the standard ones. So basically you have a standard block for a motor interface and it has a corresponding standard HMI object. The normal functions include manual/auto control and process alarming.
PCS7 uses the same software for PLC & HMI as standard S7 & WinCC, but they are at different revision levels. It also comes with the previously mentioned PLC and HMI library of items.
Does anyone have an example project of the cm ptp ET200 SP HA with 410-5H DCS (PCs7 9.1 SP1) for MODBUS MASTER/SLAVE communication ?
138
Hello, Is there a sequence when installing both TIA Portal and PCS7 in the same PC? First TIA and then PCS7 or viceversa? Thanks in advance.
492
Hello, I'm currently working on a project involving both PCS7 (v9.1 sp2 upd1) and a Panel Comfort system. This necessitates the use of TIA Portal...
813
I'm coming from a background of PLC ladderlogic/rockwell products. I am new to blocks. Can you point me in right right direction? What I would...
1,568
Hello everyone, i would like to read in pcs7 v8.2 the actual day of the month(ex 1 or 25 of the month) i used as attached read_CLK AND DT_DATE but...
1,943
