S71200 counts to pulses per sec
Nov 2011
Ireland
182
Hello,
I have a HSC configured to count frequency on my S71200 PLC. The max average measuring period i can have is 1 sec. I am not happy with the accuracy.
I want to now count the actual number of pulses over a longer period (maybe 10sec) and convert this value to frequency (pulses per second). I expect this involves a timer etc but i am not sure where to start.
Can anyone advise me on a program that can do this task?
thanks
Yes but i am trying to find a program that will convert the count to frequency
for example do i count and time the count in order to determine frequency. I just don't know how to implement what i want to do
I was thinking of counting a totalised count for say 10sec and storing the value then dividing it by 10 to get pulses per second etc?
Hi Folks. Has anyone used an SEW EI7C encoder with an S71200 PLC? If yes, how is it done? I use this same encoder in EI76 mode with a...
263
Hi everyone I am completely new to using shift registers and am a bit stuck, my shift register works as should, it is for an overhead conveyor...
55
15,629
Dear Experts, Warm Greetings ! By using TCON,TSEND,TRCV,TDISCON block,I am trying to make communication with my...
1,495
Hello; i'm having some troubles with a com test i'm handling. i have another end for it, but for now i would like to have : M241 in io_scanning...
3,492
I got Meinberg as NTP server, and it is in same network as My S71200 PLC. I went (Device configuration -> Ethernet Port ->time synchronization)...
2,710
