s7200 usb connection configuration
nywhr
Oct 2007
istanbul
I have s7200 PLC,PC/PPI cable (USB connection) and Microwin V4.0 program.But ı couldnt communicate each other.Can you tell me how can I configured.Also in communication window it is wrote PC/PPI cable (COM1) on Network parameters interface.,Its true or not.
Help me pls.Thanks
In the MicroWin software you should see PC/PG settings in the bottom left corner. It should allow you to select PC adapter and then USB not serial. If you can not select USB go to your "Control Panel" and set up your software and interface under "PG / PC interface"
hello I wanted to know if someone has a schematic on a convert usb/rs485 for S7 200 my converter rs232 rs485 for s7 200 that works very well...
7,040
4,811
Hi there! I know this is playing in archeologist, but I need to tune a bit some older Kollmorgen/AKD Digifas 7100 servo drive. Any chance of...
1,147
hey guys here first time for me in this awesome forum actually i have S7-200 connected to Winview HMI and HMI project file has lost and broken...
607
