Sauer Danfoss Plus+1
UnderPressure
Apr 2008
Alberta
Hey guys,
Just wondering if anyone else is experiencing trouble with Sauer Danfoss Canbus PVED coils on PVG32 and PVG100 hydraulic valve banks.
I have a fleet of these PLC controlled Canbus valves that move uncommanded or fault and lock up. Pretty scary stuff for mobile Hydraulics.
Any info or help is appreciated.
UnderPressure.
I have used +1 and PVED-CC only in one project.
What happens, is it random or is it certain valves moving the same way?
Do you get any errors using Web-GPI or if you read the Errortelegrams from your MC via the CAN-Bus?
MrQ,
The failure can be quite random. It can be a slow drift all the way to a full flow motion. Once the valve takes off their is no way to stop it without shutting down the controller.
We can read all sorts of faults on WebGPI, such as "aux valve timeout" and "main spool cannot reach neutral".
Those faults seem to be more related to the constant faulting out of the coil.
I would caution anyone using these PVED coils to monitor them closely for uncommanded movement.
UnderPressure
Pved cc problem
Hello i have used this, they givs me problem, do you find out solution?
I have meeting whith danfoss 25/11-08 about this valve, it has be good if i can have you as reference?
Coil pved-cc
How do you have solve your trouble on the PVED-CC?
I have the same trouble on many valves.
Hybride
The hydraulic company Sauer-Danfoss has a controll system especcially designed for mobile hydraulic aplications. The new generation of this is...
2,564
Unregistered
U
Guys, I've been trying to complie a prject running on a Sauer Danfoss DP610 operator panel, and in the actual code when I try to complie the code...
1,835
Hi, I need to replace damage control board of 37kw Danfoss fc360, I have a control board of 30kw of same Model FC360, how to change that board...
58
Hey guys. As the title suggests, I need to configure a Danfoss Aquadrive FC202 inverter, so that its logic inhibits the local command when the...
90
Hi all, We are currently experiencing an DC over voltage fault on one of our inverters. During commissioning a snag was raised whereby excess...
261
