Saving actual values in DB-Blocks
mulderm
Jun 2003
Netherlands
298
Hello,
I using Siemens Step 7 software.
When I open a DB-block in the data view and click on the
monitor button I can see the actual values.
When I close the monitor button the actual values are zero.
How can I save the actual values in the DB-block so I can
see later in offline the values?
And when I have many DB-blocks how can I save the actual values?
Greetings,
mulderm
Hi
You need to "upload" the datablocks.
From within Simatic Manager click the icon at the top that has the tooltip "online"
When your project opens online, select the datablock(s) you want and press CONTROL (CTRL) + C (or click edit and copy) and then CONTROL (CTRL) + V (or click edit and paste) into your Offline project.
Then you'll have copies of the datablocks
Hope that helps
You wish save the actual values for what?
May be for analysing in Excel or MATLAB?
If yes, offline project is unuseful for that.
I have some methods for uploading data from DB to file (S5 and S7). But I can't share it right now because russian comments. Let me know if it is interesting for you and I will translate and share it here.
Anyone got any ideas how to save my actual values to the initial values in my DB's without doing it one by one. Or will saving RAM to ROM be...
3,671
Hi everyone, i have an issue with saving a changed value in an AOI, I am using L84E, Everytime i try to save my work to SD card, the program lost...
98
Hi all, I have installed a SICK AFM60A-S4IB018x12 encoder to Allen-Bradley CompactLogix PLC and configured its parameters via AOI provided by...
98
Hello, i have a problem, i was trying to fix a trend that wasn't registering the tags, i got that fix by setting the path, but now i can get it to...
839
I'm struggling with this...Times and Dates are always a mental-block for me. See picture. When I press SAVE, I want to take the current...
1,698
