Saving S7 actual data to the memory card
sonarbell
Mar 2004
Leicester
28
Anyone got any ideas how to save my actual values to the initial values in my DB's without doing it one by one. Or will saving RAM to ROM be enough.
My problems is when the customer does a master reset it loads the initial values from the DB's and not the actual.
Its a 300 series CPU ..
Your help is appreciated as always. 🍻
Master reset deletes all retentive stuff too. Thats my problem. I think Ive done it anyway. I copied RAM to ROM in the PLC menu list and tried it.. Seems to have worked. Stroke of luck eh !!
'Copy RAM to ROM' will save your actual values as new initial values.
Hello, I using Siemens Step 7 software. When I open a DB-block in the data view and click on the monitor button I can see the actual values. When...
3,266
Hi everyone, i have an issue with saving a changed value in an AOI, I am using L84E, Everytime i try to save my work to SD card, the program lost...
98
Hi all, I have installed a SICK AFM60A-S4IB018x12 encoder to Allen-Bradley CompactLogix PLC and configured its parameters via AOI provided by...
98
Hello, i have a problem, i was trying to fix a trend that wasn't registering the tags, i got that fix by setting the path, but now i can get it to...
839
I'm struggling with this...Times and Dates are always a mental-block for me. See picture. When I press SAVE, I want to take the current...
1,698
