Scada/plc
ali18
Jan 2009
egypt
Hi everyone here,
There's something I'd like to ask about, and it's about the communication among some system which controls a process through a number of PLCs as well as SCADA,.. particularly the communication between the SCADA system and each PLC in that system… The story is: there's some gas-circulating system controlled by an integrated PLC (S7-300) and a SCADA system,.. the problem lies in the SCADA, as the HMI doesn't update the data coming from the PLC, or let's say the SCADA parameters (shown on the HMI) doesn't respond to the changes happening in the field switches / transmitters,.. I guess this is because of the communication itself, as the PLC itself is still controlling everything on the field so far!!.. Would you help me solve this problem?? Any suggestions are welcome !!
Thank you so much in advance..
What SCADA system are you referring to, as this might help answer your question?
Is "all" the SCADA data not coming in, or just some? If all of it is not coming in I would say the SCADA is not "pointed" to the right device, the IP address or driver not set up correctly or something along those lines. If it's only some things not updating, it could just be they are pointing at the wrong PLC tag.
Yes, the scada doesn't update any data coming in from the PLC and the field sensors/transmitters... Now, for this <<the IP address or driver not set up correctly or something along those lines>>.. Would you help me get how to set up the correct IP address for this system??? On the other hand, in terms of the other possible solution "driver setup", does this mean I need to re-install the scada software again??
Thank you sir for the reply!!
Can you specify the hardware and software that you are using?
The SCADA package can be made from many manufacturers. What package are you using?
Regards,
Is it possible to connect a PC with running WinCC Advanced or Unified to a siemens PLC such as S7-1200 across different subnets? The computers can...
98
Has anyone used Do-More or Productivity PLCs with VTScada? Or Ignition? Which was the easier platform to use?
676
Hello Experts, I would like to know how can a PLC with modbus tcp/ip protocol can communicate with remote scada with modbus tcp/ip over gsm 4g...
1,055
Good Afternoon, I am an intermediate Programmer who has set up for part of my Wastewater plant a Two server redundant WinCC scada system with an...
1,039
Dear all, I have a FX2N-20MR chinese semi-clon of a Mitsubishi PLC. It has only a serial DB9 port that cannot be removed or exchanged (which is...
2,110
