curlyandshemp
+1 on Ignition :site:
One pet peeve I have is that for speed reasons the OPC-UA server only browses PLC tags to the word level. That's fine for numerical data, but (unless I've missed something) any tags you need at the bit level you have manually "create" from the imported words. This can be time consuming if you have a large tag database imported.
G.
+1 for Ignition.
If you are referring to Contrologix Booleans, that was several versions ago of the driver. The Inductive crew had to virtually reverse engineer the contrologix driver.
One suggestion I have given them though, is the ability to browse tags in an offline contrologix *.ACD file. I don't always have an online PLC at the start of a project.
