Schneider Electric Quantum 140 NOE771 00/01 Fault
jedi1213
Jun 2022
Singapore
I have a Modbus/TCP operational network. Last week a NOE 771 01 on one of my Hot Standby PLC System, Standby PLC stopped communicating. On its display the indication Fault, Kernel and Appl were illuminated. I replaced the card with a new one. It normalized but after a while it happened again on the same PLC. I tried with 3 new NOE cards but the fault remains. When I tested the card on a test system on my desk it seemed to be ok. The firmware and configuration is checked to be correct. What can cause this fault? Appreciate very much your advise. Thanks. 🤞🏻
Hello,
I am currently in the same situation as you, I tried upgrading the firmware on the NOE card then re-uploading the settings into the PLC. I'm not 100% sure how I fixed it but it ended up working for 1.5 weeks before failing again.
The kernal alarm appeared as soon as I tried to update the FTP password, it completely bricked the PLC.
Dear sir, I've Schneider electric Quantum series hotstandby plc 140cpu67160 and unitypro XL 2.3V and OS loader 2.31V.I've problem that when power...
6,878
I am hoping that someone here is familiar with adding a Generic module specifically a mettle Toledo IND 131 module to a Schneider Electric Quantum...
3,721
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
238
Hi, I am stuck with these SE cartridges, I am trying to add a second serial port rs485 to a M221 PLC. What is the difference between TMC2CONV01...
119
Hello, Does anyone know why this AMO 0410 or AMO0410 module flashing all 4 channels with green LED and the IO LED on the display is solid red ...
487
