Schneider Electric XBTGT6330 Memory problem
timcph2008
Jul 2015
United State
33
Hello guys,
I am using Magelis XBTGT6330. After I download my project to XBTGT6330, an error message appears:
"Variables are being logged to the storage volume, which is now either unavailable or full - Data Logging"
I did not use CF card and USB drive, and the user configuration on Vijeo designer is Main drive. From the system tag on XBTGT6330, the main drive still have space. How to solve this error?
Also I have some additional questions:
1. Does the CF card or usb drive is necessary for the XBTGT6330? If yes, why?
2. The real-time data from measurement devices should be stored in the PLC right? Does the CF card and usb dirve on the Magelis XBTGT6330 also store the data from field device?
Thank you guys, thank you so much for your help!
The problem is you are logging values...(Historical trend or something)
For this you must use external memory.
PS. if going the CF card route dont use generic cards you buy of the shelf....They dont work. Buy the schneider cards...
Usb drive doesnt matter it must just be formatted correctly
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
239
Hi, I am stuck with these SE cartridges, I am trying to add a second serial port rs485 to a M221 PLC. What is the difference between TMC2CONV01...
120
Hello, Does anyone know why this AMO 0410 or AMO0410 module flashing all 4 channels with green LED and the IO LED on the display is solid red ...
490
I have a machine that has M241 PLC. I need to add a couple of outputs to the program, and I don't have the original code. Am I screwed or can I...
474
I am using a M221 PLC (TM221CE24R) which provides me 1 Rs485 port, which I am already using to communicate with a sensor (Rs485/Modbus). My...
749
