Schneider M241 mail to google smtp
GeNiAll
Jun 2017
Quebec
Hello all
Did anyone send an alert from M241 via google smtp. Currently, Google rejects my mail. Any information is welcome.
You should try to use a Restricted Gmail SMTP server.
Google provides three different SMTP settings in which you can send email messages from a printer, scanner or application (PLC).
SMTP relay service – used to send mail from your organization by authenticating with the IP address(s). You can send messages to anyone inside or outside of your domain.
Gmail SMTP server – requires authentication with your Gmail/Google Apps account and password. Messages can be sent to anyone inside or outside of your domain.
Restricted Gmail SMTP server – does not require authentication, and you will be restricted to send messages to Gmail or Google Apps users only.
Here is a link showing sending email using a Do-More controller.
http://accautomation.ca/heres-is-a-quick-way-to-send-email-text-messages-from-the-plc/
Hope this helps you out.
Regards,
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
113
Hello, Recently I was asked to analyze the logic of the air conditioning system in one of our departments. The PLC that controls this system is...
154
I have a machine that has M241 PLC. I need to add a couple of outputs to the program, and I don't have the original code. Am I screwed or can I...
474
Hello everyone! I have a Schneider M241 as master of a CAN network with several encoders and whatnot, everything is working fairly well. Now...
1,718
I'm thinking of selecting the Schneider M241 PLC for a product line. Has anyone worked with this PLC before? Please share your likes/dislikes...
3,621
