Schneider PLC CPU 140-CPU-671-60 Power cycle
sachin.patil
Jun 2015
Pune
Hello every one,
I am using Schneider PLC CPU P266 140-CPU-671-60 in redundant configuration. I want to power off both Schneider CPU due to some work. Both CPU having Battery inside. Both PLC CPU LCD display not showing battery fault.
My question is, if I switched off & ON both CPU power then is there any loss of program inside PLC CPU or any SCADA set-point will reset..??
Please suggest...
It depends how the plc is setup in the config. Software might write default values to certain %MW.
Make a data backup of the cpu's. If values are different after bootup you can always load the backup you saved.
Hi Guys, First time posting here. I see a lot of useful information on this website. I was hoping someone could help me with a problem I am...
2,983
Hello, I have S7-417-4H CPU having Modbus TCP/IP communication with Schneider PLC. Modbus TCP/IP communication was working. But since S7-417-4H...
6,277
Hi all, I'm newbie about Schneider PLC M340 family, someone knows if is possible change the CPU IP address by means of some instruction to use...
7,900
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
141
Hi Please I have zeilo smart relay #SR2A201BD but I don't have it's programming cable. Can I use any general usb/rs232 converter? Or need...
176
