SCL syntax problem
rscott9399
Aug 2017
in space
114
Guys
Cant remember syntax for an if statment like this in studio 5000
Can someone help
If ( some_tag == false) then
do something
end_if
I can not get it to accept a comparison for a false
I have tried
( some_tag = false)
( some_tag = 0)
and a bunch of others
Nothing works
How do i execute an IF if something is NOT TRUE
No Logix SCL experience, but most coding languages I've seen usually allow either <> or != as the opposite of equals ( either meaning "neither greater or less than" or "not equal to", but result is same).
Im surprised that equals 0 or false didn't work, though.
Hi, When programming in SCL, does the compiler raise errors if there are problems such as a FOR without an END_FOR or you are trying to assign a...
5,674
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
82
Hi, I have an intermediate-advance knowledge of programming with TIA Porta in Ladder, would you recommend me to start learning SCL for it to...
566
Hello nice to meet you, im new in here, I'm currently trying to convert code written in STL for a S7-400 to SCL for an S7-1500, because when i run...
324
Hi everyone, I am new to this amazing world of PLC, well... I mean, in practice, since I already knew electronics, programming languages, IT, and...
656
