SD Card for Phoenix Contact ILC series PLC
FNC
May 2010
NJ
84
I am using a lot of Phoenix Contact ILC series PLCs. There is a slot for a SD card for saving data and graphics. Buying it from Phoenix Contact costs $140 for a seemingly blank 2 GB card with a Phoenix Contact sticker.
I tried using a blank 2 GB card but the PLC does NOT like it and reacts by disabling the ethernet port (can no longer ping it).
Why will a standard blank SC card not work?
Do I really have to shell out $140 for a damn SD card???
Thanks.
FNC
Hello,
I had the same issue with wago sd card.
i think that it has special format inside (some space are pre occupied).
Hello, new to the forum, been here over the years on and off, but now I am more involved at work so I run into more difficult problems.... Maybe...
3,980
Hi all, I need some advice on an Analogue Input on a Phoenix contact PLC inline control ILC200IB. The machine it as attached to is a Jensen...
5,059
Problem: Ever since we upgraded to fiber on our DH+ network, WonderWare has is giving us a communication status alarm from each PLC. The alarms...
9,773
Omron AD081-V1 Analog Input Card Offset & Gain Adjustment Entering Adjustment Mode 1. Set the input card in adjustment mode (Turn ON Dip SW No-1)...
88
Hi All, Has any of you tried to change the IP Gateway of the PLC (of course, essentially of the ENBT card), while in a redundant configuration...
128
