Searching for 24VDC counter
alive15
Oct 2015
Montgomery, AL
727
Good morning, could anyone recommend a 24VDC pulse counter which counts up or down to a preset #? Once it reaches this number, send a 24VDC back to the PLC saying the counter is reached? For a very small application that doesn't have HMI. I will most likely count down from 100 to 0, so when it hits 0, I need a 24VDC signal back.
Thanks,
I second the CUB series. They have output option cards (relay or solid state) and a serial communications card as well that you may be able to use to have the PLC read the setpoint and value if that's valuable to you.
What frequency is the signal? Would a PLC catch it? Would a PLC have space for a counter card? Some Digital Input cards do have counter channels in them.
Good afternoon, I have an application where we induction harden different areas on our assembly part using coils that wrap around and heat up to...
3,754
Good morning, I'm searching for a power supply to convert 3 phase 480VAC to 120VAC and 24vdc. Is there an all-in-one power supply like this on the...
111
is it just me, or has something happened with the google search when using chrome? looks likes safari on mac is ok, but edge/chrome on windoze has...
865
Besides using BootP in the past, I am relatively new to having to look for privately addressed devices in many control networks. All of the...
23
4,065
Hi, Using FactoryTalk View SE version 9.0. Wondering if someone can help me as to whether or not I can search an entire display for instances of a...
2,318
