Sending emails with rslogix 5000
BeardedBatman
Feb 2014
Toronto
Is it possible to send an email when a condition is met with rslogix 5000 only sing the 1756-ENBT/A.
I was wondering because the rslogix document explaining ethernet i/p modules mentioned that we need a 1756-EWEB
We are using rslogix 5000 on controllogix plc, the reason for us wanting to use this function is that we want to recieve an email when the process has started and stopped.
Just wondering if we can actually run it without the use of the 1756-EWEB as we do not have one in our system.
look at ENET-UM001-EN-P - February 2013
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/enet-um001_-en-p.pdf
the ENBT can send email but you must have the correct version of firmware
You also want to get TN46036 - Example of Sending an email from a CompactLogix processor
and L35E_SMTPExample.zip which is example code for sending the email
It does not matter that the documentation is for compactlogix the code is the same
also "Pub 1769-UM011C-EN-P Email MSG Example.docx"
Hey thanks for the reply, and i have been reading the ethernet i/p configuation manual with no luck...
as for those documents that you have mentioned i cannot find them online eg: the pub 1769 and etc.
just click the link provided by MichealG will take you straight To the pdf file. I saved a copy of it last night. It's the second Line in his post.
I've been having some trouble figuring out how to get the ip address for the mail relay server, is it something that I need to create separately...
938
I've been trying to get this Ethernet module configured to send emails to our relay server but cannot get it to work. the EN2T is running...
1,779
Hi Everyone, I'm using a small program to generate emails when certain conditions are met like when a counter exceeds a value. I was hoping that...
2,013
So here's the deal. I'm fairly new to red lion HMI's, and this job, but have picked up the programming enough so far to build screens and make the...
3,755
Hello everyone, I am trying to send an email with a Compact Logix L33ER. I used the example provided on the rockwell website, but it did not...
3,004
