Serial Communication with Ignition Scada
karthiknd7
Apr 2017
20
I need to connect a machine with Ignition scada to get the OEE Data of the machine. The machine doesn't have a PLC. May be a micro-controller or Embedded system running in DOS. It has four RS232 out. I'm thinking connect these RS232 with an Ethernet converter and connect to Ignition through Ethernet. For reference i have attached some of the images that i received.
You'll need some idea of what protocol this machine can speak. Are those serial ports even designed for comms to a SCADA system?
Until you know that you'll just be fumbling in the dark
i need to connect a machine with Ignition scada to get the OEE Data of the machine. The machine doesn't have a PLC. May be a micro-controller or...
1,966
Currently,we are facing the communication go through with 422 tx+ and tx-. Mitsubishi fx5u series is used and using command rs2. But the package...
114
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,577
MELSEC A RS422 (25pin) <> iQR C24 Serial RS232 (9pin) - Simple PLC Communication Communication from a MELSEC-A Series CPU (RS-422 – DB 25 Pin)...
1,055
Hey guys, I have a problem reading weighing data from AND AD4406 with OP-05 RS-232C Relay and Control input using Rockwell PLC Micro820. I already...
951
