Serial Testing
montech
Jun 2008
Colorado
30
Hello Guys
Not looking for someone to write this but I need a simple way to use an AB ML1100 to test a application using a TI chip(TL5812N)This chip takes serial data and outputs parallel to a fault anunciator panel using LEDS.I want to write a plc program which will cycle thru these leds and burn in the board after a repair.Any ideas where I should start?The timing is available for the chip in its datasheet.
Sounds like a neat challenge !
Do you already have a 24 VDC / CMOS interface circuit worked out ?
This sounds like the sort of thing you'd do with another IC, not really with a programmable controller. The clock pulses are 1/2 millisecond minimum, though no maximum is listed.
I think you'd go after this with ordinary outputs and maybe a Sequencer instruction.
Thanks Ken
I hadnt thought of that route.I can use the SEQ instructions in the 1100 to get this done.I will post the ladder when I get it figured out.
Hi, I need to test a scanner connected via RS232 / ASCII on a ET200S 1SI CP card. After downloading the hardware configuration I have fault leds...
1,377
Hi All, Does anyone know of any simple utilities for testing DF1 comms? I have a remote site several hundred kms away where a 3rd party...
2,173
hello friends i have an old ML-1400 which i purchased from a ship owner which was used in that ship now i wanted to test the serial port(DB-9)...
2,466
Looking for recommendations for USB-C to serial adapters. Mainly used to connect to SLC and PLC5 processors.
180
Does anyone know of an AOI using the user ASCII protocol select on the L6x controllers that will talk Modbus RTU using RS-485? Thanks, Trevor...
151
