Series one GE Fanuc plc rs232 interface
maca
Apr 2004
hi fellas
iam chasing the wiring diagram for the Series one GE Fanuc plc rs232 interface model no. ic630ccm390
so i can use it to hook up a pc to some rs422 gear
any help would be appreciated
Mainly to save Steve the trouble of repeating himself, please see THIS POST for some good info... :nodi:
I found it using that handy
icon at the top of this page.
beerchug
-Eric
ahh. yes i have read that post
but the 422 gear that iam trying to hook up is not the serries one plc
iam trying to use the "black brick" as a generic interface that i can use when i go out on site to provide optical isolation and conversion between my laptop and the 422 gear that is on site.
and unfortinualy i dont have the original cables.
ps I dont have the manual either
thank you steve and eric
thats exactly what i wanted.
you have saved me vast amounts of time and hassle.
much appreciated:)
as you dont know how long i was searching for that.
Got an old machine with a IC610CPU104 CPU. A bit of research told me this is the same as DL305 so DirectSoft from AutomationDirect should work...
2,066
Hello Does anybody have FANUC series 90-30 PLC configuration softwate? I need it . I have a big problem, Please hepl me...
1,769
Hi guys. Im a total PLC noob. i suspect a dead 331 cpu. Unable to communicate with it using the LM90 start utility. But i could on another CPU...
2,934
Hi All, I have just started using GE PLC and wish to check for some information. I was able to connect to my 90 - 70 PLC with COM1. I would...
2,909
Hi, I have gefanuc plc system 90-30 series and proficy m/c edition 5.3.My one NIU card showing LED status are BUS B and IO enable in amber...
1,491
