Servo Drive Overspeed - Pac Sci SC755
keithkyll
Jul 2005
Heath, TX
2,033
Retrofitted a machine with PLC-HMI. Reused existing hardware.
Main drive is a servo motor with an AC resolver. 4096 count. Drive is a Pacific Scientific SC 755. Motor is not a Pacific Scientific. Schematic says motor is a Hathaway HT09002 series. No name for resolver. Part number 61107. Built in 1998 by a company that went out of business years ago.
Motor is direct-coupled to load. Max RPM is 300. We have a separate Hall sensor that I'm using for a tach monitor.
Good speed control up to 200 RPM. Locked in. At 210, it bounces around 210-215. At 225, it runs away to 300 RPM steady. Drive continues along happy - no report of overspeed.
At first I thought bad (optical) encoder, but this is an AC resolver. Copper coils, not LED's.
About to hang a 'scope on it. Any thoughts?
Max RPM = 300 are you sure it's not 3000 RPM a 300 RPM motor would be about 20 poles
very unusual.
if your going unstable at the higher RPM's i would look at load
the type of feedback (resolver or encoder ) would be selected by the feedback card on the drive resolvers were common on older servo systems.
i would give some thought to just replacing everything to a newer drive system
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
94
I am looking for some suggestions on good Ethernet/IP servo drives to communicate with an AB PLC. My customer has a non motion PLC but wants to...
1,189
I am looking to upgrade some of our old Servo Drives to the newer kinetix 5700 style. currently we have 4 1394 axis that are all driven by 5kw...
888
Hello there! I try to to drive a HF-KN13 servo motor with a FX5U PLC through MR-JE-10C. I tested the connection between the servo amplifier and...
680
