Set direction on K300 from micro830 PLC in CCW
tonyaL
Mar 2016
Indiana
Hi I am running a CCW application to control a K300 servo drive. Most of it works with the exception of being able to change the motor direction. I can go into the motor setting and reverse polarity manually which changes direction, but cant seem to figure out how to change that through the program. I believe I am connected to the correct pins on the drive. I am running in indexing mode, not step and direction. Any help would be appreciated.
It would depend on what type of index you are running. Also, set one index for the forward direction and a second for reverse. You then select which index to run. Look at 2097-UM001.
Hello, I still do not have equipment in to test. But the RTAC ladder does not have a timer reset coil. I wonder if a reset coil on Timer.IN is...
122
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
61
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
398
Omron AD081-V1 Analog Input Card Offset & Gain Adjustment Entering Adjustment Mode 1. Set the input card in adjustment mode (Turn ON Dip SW No-1)...
115
I was loading a program onto an XE1e2 PLC and it got stuck on these two windows and won't progress. It won't let me connect from the PC to reload...
99
