Setting Default Path in RSLogix5, 500, 5000
evilpig
Jan 2007
MN
29
I'm looking for a way to set the default path for RSLogix5, 500 & 5000 when a new user logs on to one of our programming PC's. We are currently using (CPR7) on both XP & 2K. It currently sets it to the new users My Documents directory & would like to set it to say "c:\Projects".
For RSLogix5 and 500 open RSLogix then click on tools then click on options (see pic). Not sure about RSlogix5000 I don't have that software.
Thanks for your reply. I was looking for an automatic way of setting both the 'Project files Search Path' & 'Directory to Hold Libraries' options automatically to ie 'c:\Projects' when a new user logs on to the machine. The reason is I am upgrading some of our older PC's to new ones. The logon script onto the domain sets the users 'My Documents' directory to a server directory if available or the 'Documents and Settings' subdirectory of the user if there isn't one. In either case if the user makes a change to the program and doesn't change the path, it doesn't save the program to the correct directory on the PC.
On our system, on the HMI we've got a page of setpoints. These are the values at which alarms are set (e.g. a high temperature alarm or a low...
1,243
Dear All experts, I have one old PLC Rockwell SLC 500 5/03 and its serial port (RS232) port is not responding on RS232 DF1 driver. I dont have any...
18
4,093
Good Morning all can you help/advise me im have a configure ge9 driver Called ge9.ge9 path is (C:\Program Files (x86)\Proficy\Proficy...
2,816
Hello all, trying to figure out how to set the default printer through RSView32. Application.Printer doesn't work like it would in Excel or...
2,040
7,325
