SLC 500 5/03 is not Resetting to Factory Default
nikhilbcs
Jan 2017
dubai
27
Dear All experts,
I have one old PLC Rockwell SLC 500 5/03 and its serial port (RS232) port is not responding on RS232 DF1 driver.
I dont have any supporting gateway or module to communicate on DH485.
I have seen there is one method to make PLC reset to default but i tried it too many time which is not resetting it to default.
Can someone tell me is there any other way to reset SLC 500 5/03 to factory default.:mad:
I have had trouble with some in the past and had to take them back to my office and short them good with a copper wire for more than 60 seconds.
Yes it was disconnected for long time. But when i see there is some program working on it. I.e when i put the key in "Run mode" 1 output is getting on and off indicating program is in RUN mode. And having No fault status and Fault battery status .. I repeat it around 10 time but still program is running...
What is the step after doing short.
What i did is
1. Short for 60 Sec
2. then connected my processor
3. then battery
4. then powered it on.
This should be work??:confused:
Is your battery disconnected!!! Do it for longer, some times it takes minutes.
It will work!
Im not sure what the default would be on the 503, could it possibly be set to load from eeprom on boot fault.
I dont see any mention of memory module in the manual under restoring to default
Please help! I have been working on this for so long that I am probably overthinking this setup and am missing something very basic. I am trying...
2,223
How do I use a self resetting timer for a SLC 500? I was instructed to use a self resetting timer as an OR branch but it won't let me use a TON...
9,717
I have a program that I've used 100 times. SQO settings: File N7:0, Mask 0FFFFh, Dest B3:1, Control R6:0, Length 8, Pos 2. Length & Position...
48
980
Everyone, i am in the process of purchasing the Slc 500 version of software to support what we have and i have a question. Several of our...
775
In a slc 500 plc I am trying to move data with out using a lot of moves. I want to move data from n7:1 to n7:2 and data that was in n7:2 to n7:3...
1,368
