Setting IP Address on Ethernet Module Slc 500
I'm assuming you mean the SLC-5/05 controller with an onboard Ethernet port.
Out of the box, the controller is set to be assigned an IP address by a BOOTP or DHCP protocol server. RA includes a utility that does exactly this with RSLinx.
The IP address is part of the controller's program, so you can load a program in via the Channel 0 RS232 port that has the IP address configured in the program.
Look on the project tree on the left side of RSLogix500.
Find a tab called Channel Configuration. You will find the channel configurations for both serial and ethernet there.
Slc 5/05 plc ip adress chnage ..need help
Hello,
I want to change ip address of SLC5/05 ...How can I change it ?
I am using " Ethernet device " driver in RSLinx Classic.
Thank you for your support
The SLC-5/05 controller stores the IP address as part of the user program, rather than as a separate module configuration stored in nonvolatile memory like the ControlLogix and CompactLogix controllers.
You must use RSLogix 500 software to change the IP address in the Channel 1 Configuration section. This can be done online or offline.
Thank you very much geniusintraining person,
My SLC 5/05 has already assigned ip address so If I want to change ip address , Should I do the same steps as here...
step 1 ) Under Channel Configuration... type new IP address and Subnet Mask under Chan. 1 - System tab ??
And I am using " Ethernet Device " driver in RSLinx classic so I add new ip address under host id.
Is that correct process ??
The only thing I would add is that after you upload the new IP address and add that address to RSLinx you will need to change the communications path. This is done via the “controller properties” (in the project tree) and then “controller communications”. The simplest way is to select “who Active…” and select your controller from the RSLinx box that appears.
Another thing... make sure you have a free (not used) IP address that you are using on the network, you will have issues if you change the address to a address that is used
You may want to ask your IT people if you are not sure
But yes, changing it that way should also work...
Good luck!
Good luck!
Thanks Genioustraining person and Firejo....
I also have HMI with new ip address ...for talking to this HMI with PLC , I put that new hmi ip address under Host id in " Ethernet Device " and it should be talking.
Hope is the best !!!!!
Hi, I am very much a novice when it comes to PLC's I have only ever had to change the IP address on them, and go off notes left by a previous...
976
Howdy Everyone, We have an old ternary drive from Wittenstein it is a TXBA046AAQ, i got the EDS file so i can add it to RSNETWORX for devicenet...
724
I'm working to expand the capabilities of an existing product which employs the M258 controller. Currently, we have to use the post...
3,720
I recently had to change the way my MSG instructions were connecting via ethernet radios; I originally had the remote PLCs in the I/O of the...
2,008
Hi all, I'm having a curious issue with my Armor block giving a connection timed out error 16#0203 in RSLogix. I have a ControlLogix 1756-L62...
5,859
