SEW drive PD data exchange
cizzy
Dec 2005
Germany
Hello,
I have SEW Eurodrive drives MDX61 with encoder attached and my application requires 4 PD words exchange between drive and PLC.
I need:
1. Status PI1
2. Position HI PI2
3. Position LO PI3
4. Torque PI4
Do I have to use IPOS compiler to program drive to send PI4 ?
PI1-PI3 is ok to set via parameters but how to set drive to send torque on PI4.
I had excellent support from Sweden SEW office where drives are bought,they sent me manuals that are downloadable from their site.
What type of communication method are you using... i want to work on a similar project using modbus(rs485) to recieve and transmit between sew movidrve MDX60A and AB micrologix 1500.. And hopefully interface this to a HMI...Where can i get informative application data... Thanks
I think that application data may be somewhat "hidden" in order to make SEW support profitable.
I was using profinet and for setting comms its necessary to
do a little bit of C or SEW embedded system assembler programming. PM me for specific details.
Hello,
Did you manage to read the torque from the Movidrive?
I'm facing the same problem, and I can't even find the torque data in Movitools...
Boti
Hello back,
I remember it was rather easy to read the torque (or the current) with movitools studio and send it via telegram to PLC.
Check drive's actual parameters list in manuals - should be actual torque or current somewhere..
My problem was 4 instead of 3 words telegram..
Hello Cizzy
I think torque is Active current (P005).
What you are trying can be achieved easily. I usually use IPOS assembler.
I can send you a sample code tomorrow when I go back to work.
What sort of application it is? Rotational or Linear? Are you sending the target position in increments or mm/deg?
Stephen
I did use once RS485 to communicate to a SEW movidrive between a SLC500.
I had to use Message send/recieve commands on SLC. All the commands had to convert to ASCII. I still have that program If you are interested.I am not sure whether Micrologix has all the functionality to do that.
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
229
Hi , I am trying to replace an old inverter with a new one and its giving me issues . Once the new one was installed , the S7-300 PLC started...
139
What does the 24V operation of sew inverter mean? I can't make the inverter starting the motor
502
Hi All, I am facing one issue with the SEW MDX61B drive. Issue- I want to run a conveyor with this drive in two directions but it runs in...
352
Hi, I've been struggling to find information about this, even though it feels like it shouldn't be that hard. I'm working on upgrading an hoist...
1,657
