SFC Question
Sceptre
Dec 2003
28
if my action is a very simple like:
IF READY = TRUE THEN
NEXTSTEP := TRUE;
END_IF;
And my transistion is simply NEXTSTEP. If READY is a variable that is set externally, will the action continue to check the if statement until READY becomes true? or will the code continue on?
there are no other branches
Question a bit vague, but I'll try...
As a guess, I'll assume we're talking about ControlLogix.
YES
If you're having some problem, perhaps the tag "READY" is not scoped properly. i.e. the SFC program has a program-scope tag called READY and another (ladder?) program has another program-scope tag also called READY.
Howdy folks. Been doing PLC programming for like 15 years now in LD and ST, but I'm trying to learn SFC now and have a kind of dumb question... I...
1,409
I'm trying to run a transition off a Boolean variable. This variable is two other global variable flags anded together in a separate CFC POU. In...
29
8,608
I am trying to make use of a sequencial flow chart to esentially serve as my main() program. I really like this elegant approach, but I have a...
3,065
I have 6 Siwarex U and I'm comunicating via SFC 58 and SFC 59. In SFC's what are parameter IOID means? Tnx.
3,673
Hey. If you haven't already read me, first time I'm building a full project on Rockwell PLC. I started building the sequences last week and I...
131
