SFC0 and IO Field
Avatar_41
Aug 2019
Istanbul
96
Hello everyone.
I am using date and time via HMI using SFC0.
I added an entry to the PDT: value in the format Date_And_Time.
I added a value in the Temp section: Int format.
I trigger it with the positive edge of a button.
But I added IO Field on HMI Side. Format Type: Date/time
I am using this as Input/Output.
I added the PDT value of SFC0 to IO Field as a tag.
Likewise, I added the Button as Set Bit.
However, I can't run it.
I tried to read with SFC1. There is no problem in reading, but when I want to enter a value, I see a ########### icon in the IO Field. Where do you think I might be going wrong?
I have shared the photos of my project below, can you help me please?
during tring to force hour,minute,seconde of the cpu from pc i get the retval 32897 in sfc0 i dont unterstand the problem the : hour is in...
1,651
I am not sure why this is requested, but it was asked. Currently I have one PLC , with one output to a relay, turning on a field equipment (just...
233
Context: PLC= S7-1212C, HMI=KTP1200 Basic. Hi again, When the "REPORT" button is pressed (on a different screen), it takes the operator to the...
677
Looking for a LIDAR sensor (2d) that we can use with a Siemens PLC for measurement, Would like to interface directly with 4-20mA or a Field bus...
991
Hi Guys, I am doing a project that involves a Ring Configuration with 1756-EN2TR with Field Fiber Device 1783-ETAP2F and 1783-ETAP1F. I am not...
2,125
