sharing data between schneider PLCs
wouter94
Sep 2017
Belgium
hey,
I'm working in somachine basic with TM221 PLCs. At the moment i'm making a program to control some machines. but I need to share data between PLCs. I have some %MWs that needs to been know by both my PLCs. Is there a way to link the PLCs so they share the values in those %MWs?
thanks for the info. found a solution. under function blocks you have some comunicationblocks that do the trick when you connect the PLCs with a serial line
If you have a ethernet port there is also a built in function for sharing variables with in/out tables
i tried to set up a in/out table but i keep failing and i don't know what i do wrong. Is there a manual somewhere? By both my PLCs i enabled modbus mapping. Then i both gave them unit ID 14 And i did put values in %IWM0 and %QWM0 but i'm unable to read those values on the other PLC that is connected with the same network
G'day All. I am having a problem with a conveyor system which is controlled by two different Mitsubishi PLCs and below is the CPU information...
1,717
Hey guys, I'm hoping for some help here. Normally my machines are small enough that one L62 can handle the load with average cycle times around...
2,757
Hi Friends, I want to Integrate data from a DSE 8610 Power sharing Module onto a PC via Modbus. Which amongst the two methods below is better...
2,055
I have the task of trying to get a AB ControlLogix to communicate with a Honeywell C300 controller. I did do some searching but really did not...
3,407
Good Day Guys. Just want to ask how am I able to share a data, particularly a (%R) to another PLC. Let's say (%R0001) of PLC 1 is needed by...
2,957
