I've recently had reports of people getting shocked from a 24volt light curtain. I've checked everything out and I don't see any major issues. The machine appears properly bonded and grounded and the curtain does not have a ground, only a drain which I assume isn't connected inside the actual unit. I've never been shocked by 24volts before so I'm trying to figure out where the shock is coming from (they claim is repeatable when its happening and not static).
The only thing I noticed is the 24volt power supply doesn't have the 0vdc grounded. Is it possible the 0vdc is raising high enough to shock someone?
Thanks!
Thanks!
