Electric Shock Drowing
Agree with plutonium.
Isnt GFCI relays mandatory over there ?
But thanks for the tip about electric shock when swimming. Essentially one should swim in the direction where the "tingling" becomes less.
GFCI is required on almost everything these days. Each code revision adds more and more. I think the common "joke" (not that this is a joke) is "Do you plan on using that recep? Then it requires GFCI". GFCI is more commonly accepted these days. A few places are still arguing over the growing Arc Fault protection requirements.
But, that doesn't mean every installation is done to code, installed by qualified persons, or inspected. Not to mention systems that could be decades old.
While I've never been shocked while in water, I wonder how much a slight tingle would feel when compared to a brisk sensation of early spring water temperatures? And how likely one would be able to react to and swim away from an unknown power source given a choice of 360 degrees.
Alabama, where this happened is currently using the 2014 National Electric Code. I don't know if the new 2017 code has anything to address dock side installations. Even so, most installations are "grandfathered" in to leave in place unless renovations are done.
My own pathetic state of Illinois, besides not even being able to pass a state budget for almost 2 years is still using the 2008 code without any type of plan to move forward.
Same thing happened a few years ago at a local marina. Two boys and their father were killed. 1st boy jumped in off the dock and was immediately in distress. 2nd boy jumped in to help, but was overcome. Then, the father jumped in...
They didn't know that an extension cord with a tool plugged in fell off the dock. Investigation concluded improper wiring by a non-licensed handyman.
Rs485 module then 2 wire belden 9841, modbus network picking up electric meters. Does this need to be wired as a ring or a radial? Thankyou
95
Hello PLCS.Net Forum, First time posting. Let's assume I am a novice. BASIC PROBLEM: My servo/linear piston is no longer zeroed to the...
236
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
246
Hi Friends, I am facing a problem with encoder adjustment in Sew Electric Cylinder CMS71L. encoder using is Sick Hiperface Drive is MOVIDRIVE...
17
806
Hi, I am stuck with these SE cartridges, I am trying to add a second serial port rs485 to a M221 PLC. What is the difference between TMC2CONV01...
123
