Shortcut to save tag files in RS-Logix 5000?
alive15
Oct 2015
Montgomery, AL
724
Good afternoon,
I'm resaving tag files over and over in order to transfer into an Automation Direct HMI. Is there a shortcut key that saves the tag files, instead of clicking "save as", then changing file type, etc.
Need to find a way to eliminate tedious work.
Thanks,
Ctrl Shift S ? (Maybe)
Lots of good keyboard maneuvers, like alt tab to change programs. Or Cntrl tab to switch between CLX ladder and tag monitoring
we have same HMI 2PC / SET LOCAL STATION version 9.0 patch 2021.dec and win10 pro v18.xx 1pc install logix5000 v19 v20 It was going well...
212
To copy a tag name in S5k we can, *right click an instruction *open the edit properties dialog box *and then copy the tag name text If we...
1,564
Is there a tag properties keyboard shortcut in RSLogix 5000 for an existing selected tag? I know Ctrl+W will allow you to create a new tag. But...
2,447
Hello all, I am having trouble when I try to open my .mer from the PV. It keeps telling me "Uncofigured shortcut detected". The problem is, when I...
1,459
Good Morning , This is what I get when I started a project 5 months ago , and then get back to it , with a new 1769-L33ER, into my existing ME...
1,932
