Siemens 314 IFM
briancr
Jul 2007
Port Elizabeth
231
Hi All
I have a CPU 314 IFM order number 6ES7 314-5AE10-0AB0. According to the siemens website this module has 16DI, 16DO, 4AI and 1AO.
When I insert it into hardware config and go to object properties it comes up with 20DI, 16DO, 4AI and 1AO.
Now for the strange part. When inserted into hardware config it only shows input address 124...155 and output address 124...155 and no analogue addresses.
I then went online with it and did a station upload and it came up with the same as above.
Am I missing something?
Does anyone have the wiring diagrams of this unit as both the doors have been lost over time. It is the only unit we have of this type and it is the ideal unit for teaching our apprentices.It was found in our dungeon full of dust. I have had a look at the Siemens website but it is not very user friendly
Brian
From the manual
 3,
The following addresses are assigned to the integrated I/O of CPU 314 IFM:
Table 8-2 Integrate inputs and outputs on the CPU 314 IFM
)9) &
20 digital inputs 124.0 to 126.3
of those are 4 Inputs for
integrated functions:
126.0 to 126.3
Optional utilization of Inputs for
• Counting
• Counting A/B
• Frequency measurement
• Positioning
• Interrupt input
See
s manual
16 digital outputs 124.0 to 125.7 –
4 analog inputs 128 to 135 –
1 analog output 128 to 129 –
the manual is downloadablke from here:
http://support.automation.siemens.com/GB/llisapi.dll?func=cslib.csinfo〈=en&siteid=cseus&aktprim=0&extranet=standard&viewreg=GB&objid=10805161&treeLang=en
Hi, I am using a Siemens CPU 314IFM with DI4xDC24V | AI4/AO1x12Bit module. I want to know the position of a motor by coupling a 10k Ohm...
4,003
Hi, i'm having bit of a problem with my Siemens CPU 314 IFM, the integrated analog inputs. I wire my pt100 to the plc analog input according to...
6,332
Dont know if anyone can help, We have the stated processor and all of the LED's on the front are flashing, but in a particular order, as...
5,332
Hey'up We have a Siemens S7 314 IFM plc. On the cpu is 6 leds; SF BATF 5V FRCE RUN STOP All these leds are flashing except 5V which is on...
5,083
I have established an online connection to a machine using an S314 processor. I am using an mpi connector and simatic manager. The online...
272
