Siemens S7 314 IFM Analog
Zaixu
Nov 2009
Denmark
Hi, i'm having bit of a problem with my Siemens CPU 314 IFM, the integrated analog inputs.
I wire my pt100 to the plc analog input according to the manual from their website, however all i get in view mode is -16 value.
And if i go have a look in the cpu hardware configuration, the only thing there is the cpu, i check it however it does not have an configurable analog input section, as the rack ones does where you can choose what range and either mA or V.
The input could be fried, but it does it on all the analog inputs.
Please help me, i'm such a newbie with siemens :p.
I see a bunch of FAQ's and updates, no manuals. Can you point to the specific manual you are referring to.
Oh, guess the linking doesnt work.
A5E00111190-01 is the manual number(search on it, only result).
Name of manual:
PLC S7-300,
CPU Specifications CPU 312 IFM
to CPU 318-2 DP
Hi, I am using a Siemens CPU 314IFM with DI4xDC24V | AI4/AO1x12Bit module. I want to know the position of a motor by coupling a 10k Ohm...
4,003
Hi All I have a CPU 314 IFM order number 6ES7 314-5AE10-0AB0. According to the siemens website this module has 16DI, 16DO, 4AI and 1AO. When I...
4,088
Dont know if anyone can help, We have the stated processor and all of the LED's on the front are flashing, but in a particular order, as...
5,332
Hey'up We have a Siemens S7 314 IFM plc. On the cpu is 6 leds; SF BATF 5V FRCE RUN STOP All these leds are flashing except 5V which is on...
5,083
I have established an online connection to a machine using an S314 processor. I am using an mpi connector and simatic manager. The online...
272
