Siemens 315 2DP Bus fault
Dec 2012
India
Hello everybody!!
One of our machines have a Siemens 315 2DP and a Micromaster 430 drive. While powering up the drive (400V, 3 phase) the Siemens CPU drives to Bus fault.
The power circuit has been isolated for the time being i.e Micromaster power has been given separately and the machine has a separate power.
It seems to be due to inefficient earthing. Please advise if anyone had faced such problems before.
Hello everybody!!
i guess, CPU's communication partner is not responding or failed if they communicated over profibus. but that is my guess and 2 cents.
Hello MOeZ!
Thanks for the reply. The Micromaster 430 is controlled by DO and analog. The bus fault occurred spontaneously after the drive power contactor is ON.
Regards,
Rajesh
i think one of the slave in the bus has been in halt ...just check in the hardware config which one is...some time it just solved by re powering the slave.
BR
Harry
I'll preface this by saying this is the first time I've worked on a Siemens system and I'm fairly unfamiliar with them. I might mess up some of...
29
745
Hi We were having a few power cuts and the CPU would not work. I had to reset the memory and he CPU would read from the memory card and start...
3,162
Dear Sirs, I had a problem with CP 343-1 with CPU315-2DP.I had newly add the CP343-1 Ethernet module to the hardware to allow me to access this...
2,632
Hello Experts I have a little problem in dealing with addresses. I am using a profibus absolute encoder Hengstler make. This encoder is spec2:64...
4,352
Hi All, One of our clients wants to replace some obsolete VFD's on their plant. There are two S7-315-2DP plc's and drives are connected via...
3,461
