Siemens CP 343-1
Apr 2003
Belgium
434
Hi there all Siemens freaks,
I'm testing an CP343-1 (industrial ethernet) and I slipt into a problem. I'm using a Cp343-1 ver 2.1 and the version on my step 7 software is version 2.0. My Cp-card stays in stopmode and it's producing an system failure (SF). When I look into the diagnostics I get the message fatal configuration error. The card is still in the factory settings. Do you think that this fault is the result of the version differences? Anyone ever encountered the same problem?
thanks in advance
Hello!
I've had the same problem with the MODBUS card from siemens..
The fault was that the configuration program was to old.
You have to check for your self if there ia a newer version in the siemens homepages.
Or the problem could be that you have not downloaded the correct file to the card?
If have found the problem. I made my hardware configuration in my S7 project and downloaded it into my cpu. The only thing that was required was that I just needed to select a network. It doesn't have be the right one but just select one and then the CP card goes in run.
Nif thanks anyway
Hi everyone, I want to upload the program from my CPU317TF-2 DP to my PC via connecting to CP 343-1 Advanced since it has LAN ports and the CPU...
184
Hi, I have a customer with a S7300 from around 2013 which they link to approx 25 inverters, 3 DP to DP converters and 5 IM153 remote I/O units...
334
Hi all , We have a trouble in CP 343-2 Asi master module having issue . When we replace new module we followed the procedure like below. But...
2,106
Hi all, I have a CPU315-2 PN/DP with a CP card, which is CP343-1 Lean. I have a PI server and am trying to connect to the Lean card. I can ping...
3,757
Q1) Can I add a CP 343-1 CP (6GK73431EX300XE0) to the Right of the 314C-2DP Compact CPU (6ES73146CH040AB0) to allow programming access over...
1,177
