Siemens cpu 155h problem
milind patel
Apr 2009
nadiad
Hi..everybody...
I have one problem and i need solution a bit urgently..
I have one system with CPU 155H in one plant.
There are S7 MODULES connected with this CPU on profibus as remote i/o.
The I/O interfacing module is ET 200M, IM 153-2.
Now , the problem is one of my S7 ANALOG INPUT CARD HAS GOT FAULTY. Analog input card is 6ES7-331-7KF02-0AB0
This module is connected with active bus module.
The Active Bus Module installed at the backplane of the faulty Analoginput card is BM PS/IM153 , 6ES7 195-7HA00-0XA0
Now my question is,
1) Can i remove my analog module online without CPU being go to stop.?
2)Can i insert same MLFB analog module without CPU being go to stop?
3)Cpu is S5 155H
6ES5948-3UR13
4)If i cant change module online, what i need to do to change the module without CPU goes to stop..
I have not used the H-system, but the S5 cpu's have got some OB's that prevent stopping caused by different errors. I don't have the manual right here, but I presume you've got one. Look up the description of the OBs. Check if the OB for adressing error and programming error are already loaded.
Kalle
Hey when I turn on my Siemens PLC CPU 216-2 after runing 10 minute it's stop and showing SF indication after I turn off and some time later turn...
122
I was trying to communicate between Siemens ET200S IM-151-8 PN/DP CPU to Rockwell Allen Bradley L73 through Hilscher Gateway NT100-RE-EN. Using...
113
I'll preface this by saying this is the first time I've worked on a Siemens system and I'm fairly unfamiliar with them. I might mess up some of...
29
749
Has anyone come across this kind of problem: I have 1215FC cpu with profinet and profibus devices. Because of one device, I would have to...
977
First of all, it's a pleasure to join this community, I already have a few years of exp in this sector but never registered on a plc forum, so...
793
