Siemens cpu 313-c
gandr
Dec 2009
GREECE
37
Hello everybody
i have a cpu 313-c and when i am terning power on
all leds stay for a sort time on and after go off exept
sf led blinking has any body an idea where the problem is??
Thanks..
Hello everybody
Thanks..
Hello gandr;
Whenever a S7 CPU shows a SF LED, it is best to go online and open the Diagnostics buffer. This will give you a list ofr all events that have been recorded recently (depending on the number of records your particular CPU can hold). To daignostic buffer you hav to click on the Blocks folder of your CPU then press Ctrl + D
It generally can give you a good idea of your problem.
Now, as it happens at startup, I would look at the MMC card slotted in your PLC; it is required for load memory, so if you don't have one or the card is unformatted thern you will experience such behavior as you describe.
Hope this helps,
Daniel Chartier
Hey when I turn on my Siemens PLC CPU 216-2 after runing 10 minute it's stop and showing SF indication after I turn off and some time later turn...
122
I was trying to communicate between Siemens ET200S IM-151-8 PN/DP CPU to Rockwell Allen Bradley L73 through Hilscher Gateway NT100-RE-EN. Using...
113
I'll preface this by saying this is the first time I've worked on a Siemens system and I'm fairly unfamiliar with them. I might mess up some of...
29
749
Has anyone come across this kind of problem: I have 1215FC cpu with profinet and profibus devices. Because of one device, I would have to...
976
First of all, it's a pleasure to join this community, I already have a few years of exp in this sector but never registered on a plc forum, so...
793
