Siemens CPU 555 Fatal Error Code 0104
HJTRBO
Jul 2008
Melbourne
618
Hi all,
I got called in just before midnight to one of our lines and I found the "CPU Good" LED was off.
After realising that I couldn't go online through the program port expander (I was just about ready to remove the battery and erase the CPU instead!) I changed the RS232 port 1 dip switches to 9.6k baud and finally got inside the thing. (Ports 1 & 2 are linked to the SCADA computer) I ran auxillary function 29 and it returned a fault code of "0104" which I believe is a C memory error according to the documentation. I restarted the CPU from within the software and that seems to have got us going.
I'm not sure if I'm allowed to post the OEM code?
Is anyone able to elaborate on that error for me? I am a plant electrician not a software engineer.
Hey again, Whilst my head is back in TI world again, the system that the 555 is on has numerous profibus slaves, so I'm running through a mental...
1,453
Hi all, Before I start I have tried searching, but unfortunately I am not coming up with anything useful... ... And I also feel a little shy...
2,918
Hi folks, Anybody knows what kind of PLC program will I used in programming Siemens 555 CPU. Any website where I can download such program...
4,764
Hey when I turn on my Siemens PLC CPU 216-2 after runing 10 minute it's stop and showing SF indication after I turn off and some time later turn...
126
I was trying to communicate between Siemens ET200S IM-151-8 PN/DP CPU to Rockwell Allen Bradley L73 through Hilscher Gateway NT100-RE-EN. Using...
113
