Hi all,
Before I start I have tried searching, but unfortunately I am not coming up with anything useful...
... And I also feel a little shy about asking this as I have learnt so much about programming S7, but I am now realising that the "degree in one weekend" approach will require more like 6 months...
Formerly bit bashing of Mitsubishi / Omron, I'm now the new sole Sparky at a plant full of Siemens so this situation becomes a welcome learning curve.
Question 1)
We have a 3 layer blown film extruder with a CPU 555 (interfacing with an industrial PC) at address 0 (according to the schematics) and then around 20 profibus nodes originating from this CPU. I attempted to plug into the profibus network and I changed my address of my PG to an unused address but no luck displaying accessible nodes. Is this because the CPU 555 already holds the master address of 0?
Question 2)
I have S5 for windows and a TTY cable but I cannot establish a connection with a S5 100 CPU. The CPU has no EPROM or I/O attached to it. I just figured I could plug it in and start getting used to S5. Any ideas on why I can't go online? I did find some search information on this question and the replies indicated that there should be no trouble. So I figured it's either my comm settings (which I will eventually work out myself) or the lack hardware attached to the CPU. Please advise?
I have configured and programmed simple S7 300's and imported GSD files into the hardware manager as well as creating a virtual profibus network (for VIPA) so my knowledge is slightly above zero.
Step 7 V5.4 SP1
IBH S5 / S7 for Windows Version 5.03
MPI - RS232 cable
TTY - RS232 cable
I greatly appreciate any help / guidance you can offer.
Question 1)
Question 2)
Step 7 V5.4 SP1
MPI - RS232 cable
TTY - RS232 cable
