Siemens CPU Internal error ? Reason ?
userxyz
May 2002
any
2,768
This morning a customer of us called because nothing worked on his machine. I connected via VPN. The CPU state was STOP. I did a Warm-Restart and all was okay.
Here some diagnostic info of the cause:
What can we do to prevent that it happens again ? New MMC, New CPU ?
Could you give me the complete diagnostic data from this PLC (use the "save as.." button) and the order code from the CPU? Did this happen after a voltage drop?
Probably noise, brown-out, or other power supply problems.
But could also be because of a firmware bug.
What is the exact type # of the CPU ?
What is the firmware version ?
Hi! Is there any internal temperature sensor in the S7-1500 CPU (processor temperature)? If yes, is it accessible from the user program code? We...
3,684
Hey when I turn on my Siemens PLC CPU 216-2 after runing 10 minute it's stop and showing SF indication after I turn off and some time later turn...
130
I was trying to communicate between Siemens ET200S IM-151-8 PN/DP CPU to Rockwell Allen Bradley L73 through Hilscher Gateway NT100-RE-EN. Using...
113
I'll preface this by saying this is the first time I've worked on a Siemens system and I'm fairly unfamiliar with them. I might mess up some of...
29
763
Has anyone come across this kind of problem: I have 1215FC cpu with profinet and profibus devices. Because of one device, I would have to...
978
