Siemens DB memory. I don't understand.
sapoleon
Aug 2003
salta, salta
315
Hi, I have a misunderstanding when working with the Siemens PLC's.
I use DBs that I create, and also instance DB from the FBs. I know that I have the Working Memory, and the Memory in the MMC.
So, the question is, what is stored in both the memories? when the working memory is load?
And, another thing, is if I reach the limit of the MMC, but I still at 50% of the working memory, is it just a question of buying a bigger MMC to solve my problem?
thanks for your comments.
1. The load memory is located on a Micro Memory Card (MMC). The amount of load
memory corresponds exactly to the MMC. It serves to store code and data blocks
as well as system data (configuration, connection, module parameters, etc.).
Blocks that are identified as non runtime-related are stored exclusively in load
memory.
You can also store all the configuration data for your project on the MMC.
The RAM is integrated in the CPU and cannot be extended. Its only purpose is
processing of code and user program data. Programs only run in RAM and system
memory.
2. Yes.
Hi, Yesterday, I was at a customer site. I made one little change. Changed a dummy bool output to an actual output. I didn't add any tags, or...
365
Sorry for the basic question: On my HMI, I've created a button labelled SAVE to save the current values (distances in mm). It's not linked to any...
22
2,288
Hi Guys, Is there any way of compressing the "Work Memory" of a Siemens S7 1200 CPU. I did change the installed card from a 4mb to a 12mb. I...
16
9,100
I got backup program from the machine manufacturer and I blow the flash card with this program and did the over all reset but CPU 948 is not...
1,348
Hello, I have to replace a Siemens (S7-1500F) PLC by a PLC from Allen Bradley (compactlogix 5370), but because of the different ways of...
3,450
