Siemens DP DP Coupler information needed
sujithwins
Aug 2006
banglore
I am using a DP DP coupler (as slave) between two ABB controllers (Masters).
During configuration:
In Master 1 the first module is 32 bytes read and in Master 2 the first two module is 16 bytes write.
When tested data transfer seemed to be working good.
But when we Remove the profibus plug for Mater1 and put it back the unit does not start communicating on its own, changing the termination resistor status or taking off the power makes it work again.
Any help would be appreciable
I can't actually help here, but I think the title of your post is misleading.
It really shouldn't be "Siemens DP DP Coupler information needed" but "ABB Profibus Master information needed". Unfortunately I have zero knowledge of ABB DP Masters.
On any DP network the master controls everything that happens. The slaves just do what they're told. If this system isn't doing what you expect you need to check what the masters are doing, not the slave.
The Siemens DP-DP Coupler is one of the simplest and least troublesome DP slaves I have ever encountered. It just does what it says on the tin.
The information that i need on DP DP is,Can we have 2 blocks of 16 bytes (boolean signals) in Master 2 writing data into 1 block of 32 byte in Master 1 (boolean signals), Does DP DP support this type of setting??
Hello all! I have a PN Coupler connecting two PLCs, one on X1 and one on X2 and am able to transfer data using the IN and OUT configuration...
1,187
Good morning everyone, I am trying to communicate 2 schneider electric PLCs through a Siemens DP DP coupler (6ES7 158-0AD01-0XA0), the profibus...
2,115
I am currently doing a college final year project. What i had to do was to control multiple networks via profibus from the one master station. The...
60
17,555
Hi all, I am in need of some help. I am having to interface with a customers system. I have a siemens 315 PLC with a CP342-5 The customer has a...
3,706
How are you guys? I’m struggling on the configuration of DP/DP coupler. I followed the configuration steps on manual step by step, but still not...
5,649
