Siemens Drive ES Basic
Mike_RH
Sep 2006
Toronto
896
Can anyone tell me what this software will do, that Starter does not?
When I ask my local Siemens guys, the drive guy says its a PLC thing, the PLC guy says its a drive thing, and I going WTF?
When / why do I need it?
My understanding is that Drives ES will integrate into your Simatic Manager software. This way you can save one project file that contains your PLC program and your drives configuration.
Hello Mike;
Have a look at the following information from dsiemens:
http://support.automation.siemens.com/WW/view/en/43265497
Summarized:
Advantages a Drive ES Basic installation with respect to all of the individual tools (STARTER Stand alone, SIMOCOM U/A and DriveMonitor)
    • Drives can be more easily integrated into the hardware configuration of SIMATIC S7
      using the Object Manager (SlaveOM and DeviceOM) instead of using GSD files.
    • Communication that also extends beyond network limits using routing in the SIMATIC and SIMOTION stations.
      Without Drive ES, the individual tools can only communicate with drives, which are
      connected to the same subnetwork (PROFIBUS, PROFINET) as the engineering PC/PG.
    • The tool can be directly called from the SIMATIC Manager in a context sensitive way.
      When this is done, all of the network infrastructure information is automatically transferred for the routing.
    • Data is archived/saved in the S7 project
    • Direct communication via PROFIBUS
      Without Drive ES, the DriveMonitor can only communicate with drives using the
      USS protocol via a serial interface or via a PROFIBUS-OPC server
Hope this helps,
Daniel Chartier
Thanks Daniel,
That link helped, but I am still a little unsure of the difference (benefits) of Drive ES vs Starter.
This part is not true:
"Communication that also extends beyond network limits using routing in the SIMATIC and SIMOTION stations.
connected to the same subnetwork (PROFIBUS, PROFINET) as the engineering PC/PG."
I have succesfully had routing with only STARTER and MM4 drives. With STARTER being connected via ethernet to the PLC which connected to the MM4 via Profibus.
And this part only pertains to Drivemonitor, not to STARTER:
"Direct communication via PROFIBUS
USS protocol via a serial interface or via a PROFIBUS-OPC server"
STARTER can communicate via Profibus.
So I dont think there is much advantage to DRIVE ES Basic.
Jesper, I have also used Starter routed from Ethernet to DP, and slso integrated with Step 7. Which is why I am confused about the benefits of Drive ES Basic.
Anymore comments / opinions?
Just to give this a little bump.
What would be nice is a comparison table between Drive ES and Starter, showing / highlighting the differences.
I think post #4 explains it best
Mike- what other details are you looking for?
There's also another package called DriveES Simatic. This is a library of function blocks
for communication, converting drive parameters to data blocks, blocks for displaying alarms...etc
Greeetings i do need to connect the control Teqniques Servo Drive digitax Basic to Siemens PLC i do use Profibus communication Module in the...
3,376
Kindly, has anyone tried to control Lenze servomotors with Siemens S120 drives ? Any special hints ? Have some concerns for the resolver and servo...
238
On my machine we have MicroMaster 6SE6400-1PB00-0AA0 running a motor with a Siemens 6FX2001-5QP24 encoder. Everything was working fine and then...
298
Hi All CPU 1517F-3, Drives G120C Working on a project that is under development, so more IO will be added as we go along, to keep my drives out...
646
I have G120 with Firmware version V4.7.13. In the TIA project, I have version V4.7.10. I would like to install new firmware HSP in my project. I...
1,875
