Siemens drive with Rockwell PLC
gustavo_dias
Aug 2016
Minas Gerais
76
Hi all,
I have a doubt about communication between Siemens drive and rockwell controller. For ethernet communication, I need an additional prosoft card or can I use rockwell ethernet card standart?
Why not design a system with a Rockwell drive?
Or use a Siemens CPU and a Siemens drive. It'll make life easier
Comparing the cost of drives is difficult, since there are usually big discounts especially if you are a steady customer. Not saying how much discount we get, but it is substantial.
Yes Rob, I'll use Rockwell controller with Rockwell drive. I was only checking cost possibilities. Thanks all for help!!
You need to factor in the engineering time costs also. Controllers and drives integrate better and easier with their own 'kind'. So it'll save engineering time with it being easier and quicker to do. Plus you'll have the full functionality to play with.
Hello, I need to communicate a G120 drive with a G control unit with redundant Allen Bradley PLCs. As soon as the program becomes "checked" redundant, impossible to communicate with. Is it the fact that the control unit G is not working with redundant PLCs?
Kindly, has anyone tried to control Lenze servomotors with Siemens S120 drives ? Any special hints ? Have some concerns for the resolver and servo...
234
On my machine we have MicroMaster 6SE6400-1PB00-0AA0 running a motor with a Siemens 6FX2001-5QP24 encoder. Everything was working fine and then...
295
Hi All CPU 1517F-3, Drives G120C Working on a project that is under development, so more IO will be added as we go along, to keep my drives out...
643
I have G120 with Firmware version V4.7.13. In the TIA project, I have version V4.7.10. I would like to install new firmware HSP in my project. I...
1,860
I have a new Siemens DCM Drive and I need to know how to make it run Forward Only. I can do this if I turn the torque to 0 but I need the negative...
4,238
