Siemens drive
roxtech
Mar 2008
Township Lahore
198
I have siemens drive with technological board T400. I am un able to find technological parameter L503 or H605 in siemens stander drive software. I want to know is there any special software for access of parameter on CU board USS protocol.
Best regards,
In the Siemens MasterDrives . . .
There is a parameter, and I forget which one, which, depending on what is in it,
will enable or disable other parameters.
MadPoet.
I just pick the correct fw on both CU and T400 and connect
What software is on the T400? SPA, SPW..SPS or custom??
Look on the side of the board or d1 and d2 values in T400
Kindly, has anyone tried to control Lenze servomotors with Siemens S120 drives ? Any special hints ? Have some concerns for the resolver and servo...
245
On my machine we have MicroMaster 6SE6400-1PB00-0AA0 running a motor with a Siemens 6FX2001-5QP24 encoder. Everything was working fine and then...
301
Hi All CPU 1517F-3, Drives G120C Working on a project that is under development, so more IO will be added as we go along, to keep my drives out...
654
I have G120 with Firmware version V4.7.13. In the TIA project, I have version V4.7.10. I would like to install new firmware HSP in my project. I...
1,909
I have a new Siemens DCM Drive and I need to know how to make it run Forward Only. I can do this if I turn the torque to 0 but I need the negative...
4,258
