Puddle
I have an ET200sp module (16x DQ - 6ES7132-6BH01-0BA0) that has no diag light on it. Everything on either side is lit up just fine.
I've run a test and all 16 outputs are giving 24v, base unit is registering 24v and the power light is on. I've changed it onto a different base unit too.
The diagnostic is showing everything healthy and it seems to be working fine, so I think it's just a dead LED.
The manual says "Backplane bus supply of the ET 200SP not OK" but as I'm getting 24v on every terminal I don't think that's the case.
Hopefully I'm just an idiot and done something wrong, but if not I'll be replacing the unit because it's not going into a panel with a dead LED.
