Siemens FB41 Anti Windup
cjd1965
Apr 2007
UK
1,659
Hi
If I enable INT_Hold when QLMN_HLM or QLMN_LLM are on would this freeze the integrator and prevent the windup of the integrator?
As I see it this would freeze the integrator value if at the high or low limit
Cheers
Yes you are right!
Here's a quote from the description:
INTEGRAL ACTION HOLD
The output of the integrator can be “frozen” by setting the input “integral action hold”.
Can't remember I ever have had problems with windup on this module. What you suggest is probably already built-in
Here's a quote from the manual for modular PID from big S.
Note that it is a different FB than yours FB41.
I Action
The integral action can be activated and deactivated with the I_SEL switch. When
it is deactivated, the I action and the internal memory of the integrator are set to
zero. The I action can be frozen with INT_HOLD. The reset time is determined by
the reset time constant TI. You can also assign your own value for the integrator.
The value at input I_ITLVAL is transferred to the integrator via the I_ITL_ON
switch. If the manipulated value is limited, the I action remains at the old value (anti
reset wind-up)
Kalle
hello, I'm new in automatics, and i'm working on a speed control project for a hydraulic turbine. i'm using FB41 pid bloc, but the LMN give me 0...
2,265
Hi everybody, I am searching for some advices regarding PID controller with FB41. My program is designed for online blending with 2-3 components...
3,459
Hello all, I am an electrical engineering student working on a senior design project with an industry sponsor. We are automating a burst test...
26
13,954
Hi all. I have problem starting up a mixing plant. There is 4 PID loops in the control system. PID for: Flow Working range 0-30000 kg/h by...
2,284
Hello I am trying to understand the operation and all the parameters required for setting up the FB 41 block, I have read the Siemens...
4,117
