Siemens Graph Actions
toddster900
Oct 2011
England
35
Hi All
I am working on a set of sequences in a TIA V15 project using graph FBs. I would like to condition the graph actions to open a given valve dependant on the value of an REAL. If REAL = 1.0 THEN Valve1.Out, If REAL = 2.0 THEN Valve2.Out. Below is an extract from the help files.
In actions you can assign an operand with the value of another operand or mathematical expression or the result of an instruction. Use the following syntax for this:
Assigning the value of an operand: A:=B
Assigning the value of a mathematical expression: A:=B<Operator>C
You can use the following operators: + (Addition), - (Subtraction), * (Multiplication), / (Division), % (Modulo), AND (AND logic operation), OR (OR logic operation), XOR (Exclusive OR logic operation)
Assigning the result of an instruction: A:=<Instruction>(B)
As you are not allowed to use the compare instruction within an action I am hoping there is a way to achieve this with a mathematical expression. Anyone got any pointers on how I might be able to achieve this?
Thanks.
I should probably have mentioned that the REAL value is a setpoint relating to the selected tank and so can not be written from the PLC. I am currently using the pre-instructions to set a series of bits conditioned by the setpoint but would like to be able to reference the setpoint directly from the action to keep things as simple as possible.
Can someone explain the order of processing the actions of a step...is it top - bottom see attachment for reference. Does it process the blkmov...
2,075
the plant I am supporting uses a siemens graph function to do some of the step procedures. in several steps it waits for the step to execute for...
770
I'm still getting used to working with Siemens Step 7 Classic, and WinCC in the Simatic Manager package. I need a trend line on the MP377 HMI, and...
1,847
I am using Graph for controlling 4 pallet stops. I am also using the supervision control on the last step that makes sure the pallet reached it's...
2,031
I am working with a customer template who uses pre and post instructions in Graph. I have not used these before in Graph, and I am trying to...
1,389
