Siemens HMI and MPI
No. It depends on the model though, of course.
For example, the MP370 series have MPI,RS-232,RS-422/485 and Ethernet options to communicate.....
I'm sorry to crowd your conversation ,but I need to get more involved in the troubleshooting of another plant. Could you explain what the MPI adapter is for, and how does it work.
Thanks in advance,
MPI/DP is a Siemens protocol that supports up to ** devices, similar to that of Controlnet,DeviceNet, etc.
(Typical node system)
I am sure that the more experienced Siemens people can elaborate on this...
The simple answer is, no.
A 300/400 series plc has a 9 pin programming port built in which you can connect to the multipanel. ("2DP" versions have an additional profibus port). To reliably connect (Up to 50m) on MPI = multi point interface, use D-connectors with built in terminating resistors. Switch these on at both ends of the network. Use a "Programming" plug at the plc, which has a socket on the back so you do not have to unplug your hmi to edit/monitor the plc.
The multipanel can be programmed via an rs232 cable but the plc will need a Siemens adaptor (and software!!!).
Hope this helps
good morning, we have Siemens HMI MPI 377 19 inch, the screen is Black but its working, and we don't have backup. i have new screen, my...
3,866
Hi all, We have a system that comprises of a Siemens HMI talking to 5 Siemens 300 series PLCs via MPI. The PLCs and the HMI are about 50m away...
2,961
Buona sera, Ho dei problemi nell' interfacciare PLC S5 con HMI 2a Gen. Siemens (ad esempio KTP400) tramite IBH Link S5++. il mio obbiettivo è solo...
98
Hello colleagues, On a Siemens Multi panel (MP 377 12") of a machine (S7-300) at a customer's site, some parameters need to be changed that have...
304
Hello all. I have an ESA HMI that is connected to a Simatic S7-300 (CPU312). I have uploaded the program from the PLC which is written with Step7...
1,449
