Siemens HMI Issue
Jan 2014
Abu Dhabi
We have been using ‘Siemens MP 377 15” Touch HMI’ in one of our ETS at St. Regis Hotel since the past couple of years. From this am onwards, the HMI is just displaying a ‘white screen’ as attached. The precise model no of the HMI is also attached for your reference.
Would it be possible for you to suggest the possible cause for this issue? And if the HMI is repairable?
Does it display the boot menu and startup menu when you cycle power? If yes, then you have lost the program only. If nothing at all then it is a hardware failure.
I have an experience where a power surge wiped out the program from the mp377, just had to reload the program and it was fine afterwards..
Either way, this unit can be repaired...
Dear All - Thx 4 ur replies!
Dear Rohan - When i restart the HMI using the power breaker only the 'White Screen' appears. It doesn't display any boot menu or startup menu. I would check if restoring the back up helps!
I use the HMI simulation as our production lines are pretty big and we've put an upgrade in over the last couple of months and I've used it most...
731
Hi Guys, I have a Siemens HMI that hangs. It is ESA XB300BF4R070 running on Operating System XWIN7P01EN1 customized windows7 Pro 32-bits...
1,354
Hello Everyone, Please I am trying to create an HMI program on wincc to control/monitor an Rs5000 PLC program. The thing is am sorta lost... I...
2,126
Hi all, We have a system that comprises of a Siemens HMI talking to 5 Siemens 300 series PLCs via MPI. The PLCs and the HMI are about 50m away...
2,961
Hi. I have a Siemens HMI that is faulty and was wondering if anybody knows whether my following idea would be a quick solution to getting the...
26
10,960
